Hello Guest it is September 21, 2026, 02:10:16 PM
Author Topic: New IPS (Interactive Programming System) Professional Screen for Turn  (Read 367426 times)
Re: New IPS (Interactive Programming System) Professional Screen for Turn
« Reply #30 on: August 26, 2011, 11:22:28 AM »
Really like the work your doing and this would be something I would be interested in trying out here at our company on one of our cnc lathes that I just retro'd with the machmotion controller...I have over 30 years experience in cnc and can manually program anything but I also use GibbsCam for the more complex geometry jobs to save time for our production requirements on our lathes...I cannot however create a workable screenset for our lathe to save my life so this is where you come in if your interested in me trying out your Beta version.
If interested I will send you the lathes information you requested in your previous post.
Mark
Offline DaOne
  •  236 236
« Reply #31 on: August 26, 2011, 11:25:09 AM »
Selecting which DRO you'd like to see is fine I think. Don't know though why would someone want the old type DRO - it's either you use the tool table in Mach or not, and if you do you then you have an offset for each tool.
I can think of a couple reasons... What if you don't want to upgrade versions or the latest has an issue with your setup? Say you don't change the standard tool number = offset for tool method and just want a quick way to visualize what tool your on? Anyways its now an option (simple check box for "Use new tool offset display") and it has been added. I also added the "T" in front of the tool info no matter what option you choose to display.
What was the first version to include this new DRO so I can make sure I add a note on the screen option setting?
« Reply #32 on: August 26, 2011, 11:27:24 AM »
Sorry cannot see the M01 where bouts is it located on the screen?
Mark
Offline DaOne
  •  236 236
« Reply #33 on: August 26, 2011, 11:30:12 AM »
Mark,
I have been flooded with emails requesting testing. Yours however since it is in a shop work environment especially interests me. Yes please shoot me an email with the specs and I will add you in. Testing should start sometime next week if all goes well.
Wes
Offline DaOne
  •  236 236
« Reply #34 on: August 26, 2011, 11:35:51 AM »
Mark
Ahh... I thought you meant the stop button. No you are correct that isn't on the screen. But it will be now :)
Keep um coming guys.... this is what turn a good screen into a great one. :)
« Reply #35 on: August 26, 2011, 12:37:59 PM »
Information sent!
« Reply #36 on: August 26, 2011, 01:20:16 PM »
Mach3 v3.043.038 as per the change log.
« Reply #37 on: August 26, 2011, 01:47:14 PM »
not sure what you mean i found this version number in the help section for the software
Offline DaOne
  •  236 236
« Reply #38 on: August 26, 2011, 01:58:28 PM »
Not sure what you referring too? If its based on Dan's post above yours. We are talking about the Mach version when DRO 246 was introduced.
« Reply #39 on: August 26, 2011, 02:06:41 PM »
There is a mach script call to get the mach version - with that you can test at run time to see if you find yourself on a version that has a particular feature implemented or not. See GetMachVersion in the Mach prorammer ref manual.
www.CalypsoVentures.com
