Hello Guest it is October 21, 2026, 04:05:22 AM
Author Topic: NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION  (Read 469534 times)
Re: NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION
« Reply #20 on: March 06, 2013, 12:54:22 PM »
any chance to get a radius option in the rec pocket wizard?
would ask user for corner radii.
Kenneth
« Reply #21 on: March 06, 2013, 01:22:13 PM »
IF you are asking about the NFW Wizard "Rec Pocket" it DOES have the Corner radius feature.
Just a thought, (;-) TP
« Reply #22 on: March 06, 2013, 01:32:30 PM »
yes i was. but is it the purchased version or the default.
i have mach3 Version R3.043.066. and i can't see where to add a radius.
i looked in NFW Wizard "Rec Pocket" and "Pocket Cutting"
Thanks TP
or i may not be using NFW Wizard.
« Last Edit: March 06, 2013, 01:47:28 PM by Kenneth »
Kenneth
« Reply #23 on: March 06, 2013, 01:59:12 PM »
There are 2 pocket wiz's in the free suite w/no corner rad. option.
You must not be referring to NFS.
« Reply #24 on: March 06, 2013, 02:04:40 PM »
that must be it.
Thanks Overloaded
Kenneth
« Reply #25 on: May 11, 2013, 02:30:58 PM »
Can not get to bottom half of screen resolution is 1024x768 any help from anyone?
« Reply #26 on: May 11, 2013, 03:22:35 PM »
you should check to see if the background image is blurred also.
and in general settings put a check at "auto enlarge"
Kenneth
« Reply #27 on: May 11, 2013, 03:51:59 PM »
Could you tell me were to find Auto enlarge
Thank you a lot of this is new to me
« Reply #28 on: May 11, 2013, 05:24:39 PM »
On the top menu bar, under the Config item there is a general config screen. Its got a  lot of settings on it, down near the bottom just to the right of center is the auto screen enlarge
« Reply #29 on: May 12, 2013, 09:18:28 AM »
Thank you Men i now have a full screen
