Hello
Guest
it is
September 17, 2026, 07:46:00 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Newfangled Solutions Mach3 Wizards
(Moderator:
Ron Ginger
NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION (Read 467156 times)
Kenneth
279
Re: NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION
Reply #20 on:
March 06, 2013, 12:54:22 PM »
any chance to get a radius option in the rec pocket wizard?
would ask user for corner radii.
Kenneth
BR549
6,965
Reply #21 on:
March 06, 2013, 01:22:13 PM »
IF you are asking about the NFW Wizard "Rec Pocket" it DOES have the Corner radius feature.
Just a thought, (;-) TP
Kenneth
279
Reply #22 on:
March 06, 2013, 01:32:30 PM »
yes i was. but is it the purchased version or the default.
i have mach3 Version R3.043.066. and i can't see where to add a radius.
i looked in NFW Wizard "Rec Pocket" and "Pocket Cutting"
Thanks TP
or i may not be using NFW Wizard.
Last Edit: March 06, 2013, 01:47:28 PM by Kenneth
Kenneth
Overloaded
4,923
Reply #23 on:
March 06, 2013, 01:59:12 PM »
There are 2 pocket wiz's in the free suite w/no corner rad. option.
You must not be referring to NFS.
Kenneth
279
Reply #24 on:
March 06, 2013, 02:04:40 PM »
that must be it.
Thanks Overloaded
Kenneth
picks27t
13
Reply #25 on:
May 11, 2013, 02:30:58 PM »
Can not get to bottom half of screen resolution is 1024x768 any help from anyone?
Kenneth
279
Reply #26 on:
May 11, 2013, 03:22:35 PM »
you should check to see if the background image is blurred also.
and in general settings put a check at "auto enlarge"
Kenneth
picks27t
13
Reply #27 on:
May 11, 2013, 03:51:59 PM »
Could you tell me were to find Auto enlarge
Thank you a lot of this is new to me
Ron Ginger
925
Reply #28 on:
May 11, 2013, 05:24:39 PM »
On the top menu bar, under the Config item there is a general config screen. Its got a lot of settings on it, down near the bottom just to the right of center is the auto screen enlarge
picks27t
13
Reply #29 on:
May 12, 2013, 09:18:28 AM »
Thank you Men i now have a full screen
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
