Third party software and hardware support forums. => Newfangled Solutions Mach3 Wizards => Topic started by: RICH on April 30, 2011, 02:24:52 PM
This is the latest version of the software.
V2.86 fixes a bug where the material number was using the same DRO as the Xcenter value in the circular hole array wizard.
Whenever I make a change to the NFS wizards I will place the new version here. It will be in the form of a zip file with the name Newfangled### where the ### will be the latest version number.
To install this you simply download the zip file, and un-zip it into your C:\Mach3\Addons folder.
The normal unzip will leave this with the ### Part. If you want to keep an old version around you can leave it this way, just select it from the wizard menu. More likely you will want to delete the old folder C:\Mach3\Addons\Newfangled then rename to the new one to remove the ###
This version is vastly improved over the one I bought several years ago. The threading now works... thanks!
One bug, however, Threading does not seem to include feed speeds in the G-code?
I'm adding the feed speed to the G-code manually but it would be great if you could fix it sometime.
Jim Vogeley
Thanks for the compliments on the improvements. I have tried to make it a better wizard.
You are right on the feed. I looked at the code quickly and see that in a couple of the conditions it adds a Feed to the first G01 move, but it never adds one to the G2 or G3.
Its going to be a problem to fix in a neat way, because all the G2 or 3 moves are inside a loop and if I add Feed it will be added to every G2 or G3 line. There is nothing wrong with that, it just makes the code look ugly.
I am just finishing a major project in a set of Turn wizards. I'm sure after I release that I'll get a few bugs to track down. But I will get to the thread problem as soon as I can.
I have a Tormach PCNC and a NewFangled license for v2.75... I down loaded the v2.86 file and copied it to my harddrive... C:\PCNC3\Addons\ ...folder. It came up as Newfangled286. On the Mach3 screen built for Tormach.. I pulled down the Wizard Select and both Newfangled and Newfangled286 showed. After picking Newfangled 286 the first page showed and when I clicked on 'Material Selection' there was no response...when I clicked on 'Help about materials' the dialogue box was blank... finally, pressing the 'Continue' button does nothing. To exit the wiz I had to shut Mach3 down.
I would like to use Newfangled286 but I can't without some help......!!!
Thanks..
You must delete the old folder called Newfangled, then rename the new folded to remove the 286. It must be just Newfangled. The material button looks for a material table with the path name of \Addons\Newfangled.
Thanks for the info ..... we'll make it work..!
Aloha Ron,
I recently purchased Mach3 and the NFS Wizard license. I am also fairly new to CNC, but am loving it so far. I have version 2.63 installed on my Mikini (the latest lock-down has issues with my mill), and I was wondering if the latest version of NSF Wizards (2.86) was compatible with Mach3 2.63? When I install the Newfangled folder in my addons and try to run the Wizard, I get an empty window and it crashes Mach. The release that came pre-installed with Mach3 2.63 runs fine, but I wanted to use the latest version of your Wizards. Can you tell me what I might be doing wrong?
And yes, I renamed it by deleting the 286 at the end. I restarted the machine, etc., But it still just hangs with an empty window.
Mahalo,
Paul
Blue Planet Research/ Hawaii
I have not run mach 2.63 in a very long time, but the wizards use only the base mach screen functions, so it ought to run. I vaguely recall some screen changes with V3 of mach, but thats a long time ago. If it crashes then I guess you have determined its not compatible.
I would really figure out your issues with running the latest mach and get up to date.
I just purchased the Milling Addon License. Which addon do I use this license with?
Choose he Newfangled title in the wizards list.
The license also works with Nfsturn, CopyCat, and DrilWiz
What do I have to do to get copycat to see my license? I get a no wizard license. Using v2.86 and it runs fine and puts out gcode, but when I run copycat it displays no wizard license. Thanks in advance.
I do not see how that can happen. The wizard just uses the IsWiz() call to mach. I cant understand it working on the Mill Addons and not CopyCat.
Will you please try the DrilWiz and see what it returns?
i must be getting old but i just downloaded the 286. i have to put it on a stick so i can take it out to the shop to put it in the pc where mach is. do i unzip before i put it on the stick?
It doesn't matter where you unzipit, as long as the files wind up in the right place on the shop system.
thanks ron.
well i got the 286 installed and i got the error on line 22. dont no what that means but when i closed it and reopened it all was fine. i'll keep the older versions installed just in case i have problems.
There is a problem if you keep two versions. One must have a different folder name, like Newfangled286. This causes a problem on the setup screen because it looks for the materials file in the folder Newfangled.
It is best to just keep one version installed, and be sure its in the Newfangled folder.
I have a question about how the y axis is controlled using the nfs wizard gear cutting wizard. I am have some trouble getting it to work properly.
thanks in advance Dave
Gear cutting uses a subroutine called index.tap which is in the subroutines folder. The Y moves are in the subroutine.
The basic motion is to set Y to the first cut depth, advance the cutter in the X direction, then backup to the xstart position. Then the subroutine advances Y one step depth and the X move repeats. When Y has made all the steps to full cut depth the cutter is rotated one tooth and the cycle repeats.
any chance to get a radius option in the rec pocket wizard?
would ask user for corner radii.
IF you are asking about the NFW Wizard "Rec Pocket" it DOES have the Corner radius feature.
Just a thought, (;-) TP
yes i was. but is it the purchased version or the default.
i have mach3 Version R3.043.066. and i can't see where to add a radius.
i looked in NFW Wizard "Rec Pocket" and "Pocket Cutting"
Thanks TP
or i may not be using NFW Wizard.
There are 2 pocket wiz's in the free suite w/no corner rad. option.
You must not be referring to NFS.
that must be it.
Thanks Overloaded
Can not get to bottom half of screen resolution is 1024x768 any help from anyone?
you should check to see if the background image is blurred also.
and in general settings put a check at "auto enlarge"
Could you tell me were to find Auto enlarge
Thank you a lot of this is new to me
On the top menu bar, under the Config item there is a general config screen. Its got a lot of settings on it, down near the bottom just to the right of center is the auto screen enlarge
Thank you Men i now have a full screen
Is V2.86 still the latest version?
If so what is Newfangled Mill Wizard is it a different product? I have purchased the Newfangled add-ons licence (WinLic.dat) and am using the Newfangled wizards most of all. Should I install the new installer MillWizard_Installer_Version_1.0.13 or is this something entirely different (i.e. is it for Mach4 only)? I am running Mach3 on a SIEG KX3.
There are two sets of wizards.The Newfangled Addons are only for Mach3, they use the VB and screen design features. V2.86 is the latest.
The Newfangled Wizard for Mill is a new product that will be used with Mach4, but it is written in C++ and is a fully standalone program, you can run it on any windows PC.
The Addons are simplest to use if you are running Mach3, they are integrated into the package and just a couple4 clicks gets your code ready to run. The New Wizard has a few things the old one didnt, like engraving and some pocketing code. We are working on several new features for the Mill Wizard, so someday it will be a much better wizard.
Thank you. I must stick with Mach3 for my mill, in fact the SIEG support requires that we use version 3.041 and not upgrade from that.
Hello support team,
I downloaded MillWizard and tried it out in Metric system. I found a bug in drilling. It seams like metric units are chosen, but it keep counting imperial units.
I've added a screenshot. Milling range is 100x100mm, drilling holes are by coords in square 90x90mm. Depth set to 1mm. As you can see from the screen, depth is closer to 25mm (1").
Pretty old thread, but my observation / issue seems to be topical.
With Mach3, I run my original NFS wizards without problems.
When I run CopyCat, I can follow a path and generate a series of points; G-code gets loaded in Mach3 and can be executed.
However, if I attempt to EDIT this code, Mach3 opens the Note editor with an empty file, claiming that the file created by CopyCat could not be found. An EDIT attempt from within CopyCat triggers the same behavior.
From Win7, I can navigate to the folder in which CopyCat and other scripts write their files. Interestingly, the file I'm looking for is not VISIBLE by Windows, but is displayed if looked after by Mach3 (with a locker symbol), and it can indeed be re-loaded.
The true issue is that I don't seem to be able to edit this file.
So I wonder if I have a license to use the scripts ? How can I be sure ? I do not remember at the time of purchase if the Wizards were included in my PO or not.
Unless, there is an attribute of that folder that needs to be changed at the system level; I checked that System, Admin, Users all have full credentials for this particular folder. Only the Owner has no credentials, and when I try to change them using my ADMIN rights nothing changes, i.e. the new credentials are not granted.
Grateful for any comment you may provide, enjoy the rest of the week.
Although I don't use them I think all the Newfangled Solutions wizards, including Copy Cat, require the additional license. Perhaps check you Mach3 folder for 'WinLic.dat' if it is there then you have the license.
Howdy,
Thank you. Indeed, I do not have any other license file as the one needed to run Mach3. Thus, if your assumption is correct, the wizard’s files are « made invisible » by Mach3, even though I can use them, one at the time, but not modify them.
The copy job I must finish is not so immense and I did it the « old fashion » way. Jog, human read, human write in a file, jog, repeat as many times as needed. Done.
Enjoy the rest of your WE, Philippe
I'm using: Mach3 Version R3.043.062 - Wizards Version 2.86
Something very strange is happening and I can't seem to pinpoint where the error is coming in when using the Gear Cutting Wizard in NFS.
What happens is, after many trials, that the Y feed in the created subroutine file index.tap equates to the material choice in the wizards. So if I select hard steel (Material No4) then the feed in the Gcode (in index.tap) is listed as F4 - material 6, F6 and so on.
Am I missing something or is this some sort of bug? I can, of course, edit the index.tap file but I am wondering if I am doing something wrong.
Matt
not sure I understand what you mean. could you please copy and paste an example of your observations ? Philippe
I hope this explains a little further. Below is the Gcode the index.tap subroutine file:
G01 Y57 F1
G01 X40 F101.7
G00 Y60
X0
G01 Y56 F1
G01 X40 F101.7
G00 Y60
X0
G91 A6
G90
M99
The issue is with the Y moves. The feed for Y is F1.
The 'F1' equates to the material I have selected in the wizard.
This changes and equates directly to the material number - ie if I select material 4 then the feed becomes F4 etc etc.
The material.txt file appears to be fine (default) and if you add a new material, say 10, then, you guessed it, F10 is inserted into the G code.
I can only assujme it is a bug.
Matt
interesting ... polite way to say annoying ... wait and see if I can reproduce this sort of behavior
all right, tested with a spiral cut, your observation cannot be reproduced here. There is no discrimination in feed direction nor a transport of a material related number (tested default values 1 to 8) into the text assigned to feed in the G-code. Sorry.
BTW, which kind of job requires a direction dependent feed ?
The feed direction is required as there is a rotary table in the way and quite a large gear to cut - if that is what you mean.
Matt
ok, thank you for clarifying this. good luck with this issue.
Spiral cut? Have you tried a standard spur gear?
Matt
These are the gear dimensions (although it doesn't seem to matter)
Matt
Matt, as discussed this morning, I cannot reproduce the strange behavior you observe. I have also tried with the gear cut wizard, as you asked me to do.
Have you actually used (i.e. pressed the calc button), one page before you reach the actual gear size and cut dimensions, the speed and feed calculation available ?
I have done so, obtain for my example a feed opf 240.1 mm/min which is nicely transported into the index.tap file.
Enjoy your evening, Philippe
Ah well, thanks for trying.
Yes, I have pressed the calc buttons and even tried to enter my own values to no avail.
If relevant at all, the 'preview' option displays nothing as well.
I'll resort to manual Gcoding...
Matt
Matt, this behavior indicates some sort of bug/flaw. No sure "where" to look, however. FYI on a machine running a Win7 Corporate operating system I was capable to read / edit every file generated by the wizards. When I left this company, I had to erase the corporate Win 7 installation and replace it by my own Win 7 Pro license. Since, editing the files generated by the wizards is not possible anymore.
Mach3 is no longer supported. Perhaps if asking politely, you can get ahold of the code of this wizard and dig into the details and identify the problem.
Cheers, Philippe
I don't have any problem editing either the 'index.tap' or the New 'Program.tap' files, if that is what you mean.
Tried an earlier version of the NFS Wizards but it does not run. Could you confirm the Version of Mach3/NFS you used?
Thanks for looking, Matt
Here you go: Mach 3.043.066 and wizards 2.86 running on Win 7 Pro (not enterprise)
Glad you can edit all files generated by the wizards.
Enjoy your day, Philippe
