Hello Guest it is October 20, 2026, 07:48:34 PM
Author Topic: NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION  (Read 469503 times)
Offline Filou
  •  59 59
Re: NEWFANGLED SOLUTIONS SOFTWARE - LATEST VERSION
« Reply #40 on: January 12, 2021, 03:57:03 AM »
interesting ... polite way to say annoying  ... wait and see if I can reproduce this sort of behavior
Offline Filou
  •  59 59
« Reply #41 on: January 12, 2021, 04:16:54 AM »
all right, tested with a spiral cut, your observation cannot be reproduced here. There is no discrimination in feed direction nor a transport of a material related number (tested default values 1 to 8) into the text assigned to feed in the G-code. Sorry.
Offline Filou
  •  59 59
« Reply #42 on: January 12, 2021, 04:18:07 AM »
BTW, which kind of job requires a direction dependent feed ?
« Reply #43 on: January 12, 2021, 04:26:09 AM »
The feed direction is required as there is a rotary table in the way and quite a large gear to cut - if that is what you mean.
Matt
Offline Filou
  •  59 59
« Reply #44 on: January 12, 2021, 04:29:15 AM »
ok, thank you for clarifying this. good luck with this issue.
« Reply #45 on: January 12, 2021, 04:34:18 AM »
Spiral cut? Have you tried a standard spur gear?
Matt
« Reply #46 on: January 12, 2021, 04:39:30 AM »
These are the gear dimensions (although it doesn't seem to matter)
Matt
Offline Filou
  •  59 59
« Reply #47 on: January 12, 2021, 10:28:31 AM »
Matt, as discussed this morning, I cannot reproduce the strange behavior you observe. I have also tried with the gear cut wizard, as you asked me to do.
Have you actually used (i.e. pressed the calc button), one page before you reach the actual gear size and cut dimensions, the speed and feed calculation available ?
I have done so, obtain for my example a feed opf 240.1 mm/min which is nicely transported into the index.tap file.
Enjoy your evening, Philippe
« Reply #48 on: January 12, 2021, 12:23:52 PM »
Ah well, thanks for trying.
Yes, I have pressed the calc buttons and even tried to enter my own values to no avail.
If relevant at all, the 'preview' option displays nothing as well.
I'll resort to manual Gcoding...
Matt
Offline Filou
  •  59 59
« Reply #49 on: January 12, 2021, 12:56:58 PM »
Matt, this behavior indicates some sort of bug/flaw. No sure "where" to look, however. FYI on a machine running a Win7 Corporate operating system I was capable to read / edit every file generated by the wizards. When I left this company, I had to erase the corporate Win 7 installation and replace it by my own Win 7 Pro license. Since, editing the files generated by the wizards is not possible anymore.
Mach3 is no longer supported. Perhaps if asking politely, you can get ahold of the code of this wizard and dig into the details and identify the problem.
Cheers, Philippe
