Hello Guest it is October 20, 2026, 08:52:42 PM
Author Topic: AutoZero Plate for Z Axis  (Read 88404 times)
Offline kolias
  •  1,165 1,165
Re: AutoZero Plate for Z Axis
« Reply #10 on: March 04, 2011, 12:20:59 PM »
The Digitize LED is ON
What you want me to do?
Nicolas
  •  9,374 9,374
« Reply #11 on: March 04, 2011, 12:23:17 PM »
Thats your problem. (it should be off)
You have a short circuit between your pin 10 and ground.
Tweakie,
Offline kolias
  •  1,165 1,165
« Reply #12 on: March 04, 2011, 12:27:05 PM »
ok it will take me some time to fix this; my computer & screen sits on top of my control box and to open the box I have to disconnect / remove the computer.
I will check the connections and when I will try again.
Do I leave the code you provided or use the original code
Nicolas
Offline kolias
  •  1,165 1,165
« Reply #13 on: March 04, 2011, 12:55:46 PM »
I dont see any problem on the connections but between the GND and pin 10 I have this capacitor I was told to put
How about if I change the active low status?
Nicolas
« Reply #14 on: March 04, 2011, 01:02:10 PM »
If you touch the plate and the LED goes out then active state is wrong.
Offline kolias
  •  1,165 1,165
« Reply #15 on: March 04, 2011, 01:15:09 PM »
I did touch the plate with the alligator clip but the LED stayed ON
Also checking the volts between the plate and alligator clip is 0
Nicolas
« Reply #16 on: March 04, 2011, 01:17:34 PM »
How do you have it wired?
Offline kolias
  •  1,165 1,165
« Reply #17 on: March 04, 2011, 01:20:14 PM »
One end of the Red wire is connected to the 1/8 aluminum plate and the other end is connected to pin 10 on the BOB
One end of the black wire is connected to the alligator clip and the other end is connected to the GND on the BOB
Nicolas
« Reply #18 on: March 04, 2011, 01:31:22 PM »
Is your Alu plate touching the table?
« Reply #19 on: March 04, 2011, 01:43:22 PM »
Try connecting one clip directly to the tool and the other to the thickness plate
If your machine is like mine, spindle is electrically isolated (don't know why, depend on the mechanic)
One end of wire to the cutter,  the other to the ground from the BOB
The other wire, one end to the thickness plate, other end to input pin of the BOB
Be sure that the input pin is configured in port and pin
Jeff
