Hello Guest it is October 25, 2026, 09:29:55 AM
Author Topic: any recommendations for pendant / mpg?  (Read 24608 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« on: February 15, 2011, 10:18:44 AM »
plasma and ugly blokes who aren't paying for it - so harsh environment. i.e. shuttlepro looks cute enough but can't see it lasting to teatime - maybe I'm wrong.
Home, jog, start, stop should do it.
Ta
Ian
  •  9,374 9,374
Re: any recommendations for pendant / mpg?
« Reply #1 on: February 16, 2011, 01:42:22 AM »
 ;D ;D What are you on about Ian ?  ;D ;D
Offline stirling
  •  2,188 2,188
  • UK
« Reply #2 on: February 16, 2011, 02:55:18 AM »
Hi Tweaks - well I guess I'm asking for recommendations for a pendant / mpg that will stand up to a dirty environment and heavy handed use in an industrial environment... ;)
Ian
Offline stirling
  •  2,188 2,188
  • UK
« Reply #3 on: February 17, 2011, 02:56:05 AM »
I guess nobody uses a pendant with plasma then.
Ian
« Reply #4 on: February 20, 2011, 10:16:55 PM »
Don't know how chemical resistant or dust resistant, but I have a Vista CNC pendant and I love it. it works so much better than the Parallel model I had from CNc4pc prior to this one.
The setup was almost too simple and the controls are easy to master.
I highly recommend it.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #5 on: February 25, 2011, 09:55:02 AM »
Thanks cj - sorry it's taken me so long to reply - I somehow missed your post. Must have got lost in all the other replies  ;D
which one do you have? The P3E with the EE box looks like it fully handles E-Stop correctly - so might take a shot at that one.
Thanks again
Ian
« Reply #6 on: February 26, 2011, 10:53:50 AM »
HI IAN, I have not seen any GREAT pendants for plasma use other than the ones I have purposely built. All the normal ones eventaually fail due to the metalic dust from the plasma cutting process.
The ones I built ARE dustproof/waterproof and have lasted.
one was from a modio unit and the other was a pokey unit.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #7 on: February 27, 2011, 06:17:06 AM »
Hi Terry, thanks.
What would you say are the pros/cons of modio vs pokeys for a self build pendant? i.e as you've used both, if you were to do another pendant which way would you go?
Ian
« Reply #8 on: February 27, 2011, 10:44:25 AM »
Hi Ian, If it is a simple pendant then PETERS mODIO. iT IS STONE COLD DEPENDABLE. (my favorite)
The USB has more funtions at hand BUT every once in a while it gets a little flaky on the usb side with mach.
IF it is a fancy dancy pendant with a lot of bells and whistles then the USB would be easier to work with as it has more functions all ready  to go.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #9 on: February 27, 2011, 11:05:10 AM »
Hi Terry, not sure whether I want simple or fancy dancy at the moment so I'll take a look at both and see what I come up with.
Ian
