Hello
Guest
it is
October 25, 2026, 07:35:35 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
any recommendations for pendant / mpg?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: any recommendations for pendant / mpg? (Read 24606 times)
stirling
2,188
UK
on:
February 15, 2011, 10:18:44 AM »
plasma and ugly blokes who aren't paying for it - so harsh environment. i.e. shuttlepro looks cute enough but can't see it lasting to teatime - maybe I'm wrong.
Home, jog, start, stop should do it.
Ta
Ian
Logged
Razordance Torch Height Control
Tweakie.CNC
9,374
Super Kitty
Re: any recommendations for pendant / mpg?
Reply #1 on:
February 16, 2011, 01:42:22 AM »
What are you on about Ian ?
Logged
stirling
2,188
UK
Reply #2 on:
February 16, 2011, 02:55:18 AM »
Hi Tweaks - well I guess I'm asking for recommendations for a pendant / mpg that will stand up to a dirty environment and heavy handed use in an industrial environment...
Ian
Logged
stirling
2,188
UK
Reply #3 on:
February 17, 2011, 02:56:05 AM »
I guess nobody uses a pendant with plasma then.
Ian
Logged
cjdavis618
10
Reply #4 on:
February 20, 2011, 10:16:55 PM »
Don't know how chemical resistant or dust resistant, but I have a Vista CNC pendant and I love it. it works so much better than the Parallel model I had from CNc4pc prior to this one.
The setup was almost too simple and the controls are easy to master.
I highly recommend it.
Logged
stirling
2,188
UK
Reply #5 on:
February 25, 2011, 09:55:02 AM »
Thanks cj - sorry it's taken me so long to reply - I somehow missed your post. Must have got lost in all the other replies
which one do you have? The P3E with the EE box looks like it fully handles E-Stop correctly - so might take a shot at that one.
Thanks again
Ian
Logged
BR549
6,965
Reply #6 on:
February 26, 2011, 10:53:50 AM »
HI IAN, I have not seen any GREAT pendants for plasma use other than the ones I have purposely built. All the normal ones eventaually fail due to the metalic dust from the plasma cutting process.
The ones I built ARE dustproof/waterproof and have lasted.
one was from a modio unit and the other was a pokey unit.
Logged
stirling
2,188
UK
Reply #7 on:
February 27, 2011, 06:17:06 AM »
Hi Terry, thanks.
What would you say are the pros/cons of modio vs pokeys for a self build pendant? i.e as you've used both, if you were to do another pendant which way would you go?
Ian
Logged
BR549
6,965
Reply #8 on:
February 27, 2011, 10:44:25 AM »
Hi Ian, If it is a simple pendant then PETERS mODIO. iT IS STONE COLD DEPENDABLE. (my favorite)
The USB has more funtions at hand BUT every once in a while it gets a little flaky on the usb side with mach.
IF it is a fancy dancy pendant with a lot of bells and whistles then the USB would be easier to work with as it has more functions all ready to go.
Logged
stirling
2,188
UK
Reply #9 on:
February 27, 2011, 11:05:10 AM »
Hi Terry, not sure whether I want simple or fancy dancy at the moment so I'll take a look at both and see what I come up with.
Ian
Logged
Print
Pages:
1
2
Go Up
« previous
next »
