Hello Guest it is November 22, 2026, 10:25:24 AM
Author Topic: any recommendations for pendant / mpg?  (Read 25273 times)
Re: any recommendations for pendant / mpg?
« Reply #10 on: February 27, 2011, 03:58:01 PM »
Thanks cj - sorry it's taken me so long to reply - I somehow missed your post. Must have got lost in all the other replies  ;D
which one do you have? The P3E with the EE box looks like it fully handles E-Stop correctly - so might take a shot at that one.
Thanks again
Ian
I have the P3 but without the EE box. I already have that wired to a big button next to the door that I use that kills the charge pump.
I really like the pendant and need to spend more time using it than working. lol
« Reply #11 on: February 27, 2011, 04:14:02 PM »
IAN for plasma it does not take many features. I use fast/slow jog, set axis 0,0,0, THC up/down , move to clear part and fire torch/stop torch.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: March 01, 2011, 04:48:18 AM »
Thanks Terry. Might look at adding in run/pause/stop as well. Is start/stop torch that useful?
Ian
« Reply #13 on: March 01, 2011, 08:55:33 PM »
oH YEA, Test firing the torch after clearing the tip, Also restarting a cut mid line requires sneaking up on the cut line by starting the program then refiring the torch on the fly at the right spot(;-). Once you loose spark and the cut stops it is sometimes hard to restart in a spot that has already been cut. The torch does not want to restart in the open gap.
Also to do simple cutoffs I use the torch start to start the torch then hit slow jog to trim off scrap from the plate
« Last Edit: March 01, 2011, 09:01:10 PM by BR549 »
Offline stirling
  •  2,188 2,188
  • UK
« Reply #14 on: March 02, 2011, 08:54:46 AM »
Fair comments. Thanks
Ian
