Hello Guest it is October 18, 2026, 03:01:32 PM
Author Topic: Driver test file not working  (Read 132752 times)
Re: Driver test file not working
« Reply #100 on: January 31, 2011, 02:36:33 PM »
 ;D
Even though it's moving, I'd still check the wiring and jumper settings. Could cause problems later if it does not agree with the drive specs.
Good one Hood  :)
Offline rickw
  •  110 110
« Reply #101 on: January 31, 2011, 02:45:52 PM »
I will, thanks.
Offline rickw
  •  110 110
« Reply #102 on: February 01, 2011, 04:24:46 PM »
I fixed the wiring and it is correct according to the schematic.
« Reply #103 on: February 14, 2011, 10:19:29 AM »
rick, I am attempting to run Mach in W7 32-bit, and have had to use DriverTest, and can confirm that it does work.  I only skimmed over your thread, so forgive me if you already have it running, but if you navigate to C:\Mach 3 and then right click on DriverTest it will bring up a menu.  In that menu select "Run As Administrator".  This is the only way that it will work for me.  Let me know how that works for you.
-Tiny
Offline rickw
  •  110 110
« Reply #104 on: February 19, 2011, 05:41:13 AM »
I did finally get it to work and that is what I had to do. Windows is so crazy! Al my other computers are Apple products but I have to use W7 to run my router. Thanks to everyone who has responded.
