Hello
Guest
it is
November 23, 2026, 10:23:42 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Having an issue with arcs O ring pocket code.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Having an issue with arcs O ring pocket code. (Read 13215 times)
fixittt
290
on:
December 10, 2010, 03:23:33 PM »
We are having an issue with this g code. It works on a HAAS machine fine.
Problem is, its suppost to cut an o ring grove .5 inchs in diameter. But its giving us a 1 inch or better pocket.
Any ideas? Problems that you may see?
Logged
Carnoustie, Scotland
Re: Having an issue with arcs O ring pocket code.
Reply #1 on:
December 10, 2010, 03:40:31 PM »
Works fine here, think you may have the IJ mode set wrong, change it from General Config page from Abs to Inc.
Logged
fixittt
290
Reply #2 on:
December 10, 2010, 04:01:52 PM »
That did it! Thanks! I dont deal much with arc fitted toolpath with what I do........ THANKS BUNCHES!
Logged
Reply #3 on:
December 10, 2010, 04:19:37 PM »
Really your code should define the mode, if you had a G91.1 at the beginning of the code it would have run fine even though Mach was set to Abs (G90.1) the code would have overridden Machs default.
Logged
fixittt
290
Reply #4 on:
December 10, 2010, 04:57:27 PM »
I will pass that info along to the end user, Thank you! I dont know enough about arc toolpath yet.
Logged
Reply #5 on:
December 10, 2010, 04:59:37 PM »
You probably know more than me
Logged
Print
Pages:
1
Go Up
« previous
next »
