Hello
Guest
it is
November 22, 2026, 07:16:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
new version mach3 no dxfimport?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: new version mach3 no dxfimport? (Read 11938 times)
kkquek
9
on:
November 26, 2010, 06:46:38 AM »
I using old version mach3 1.84 with the dxfimport, but now try the new version 3.04.40 only got Lazycam import, can i copy the old version dxfimport.exe to replace the Lazycam? because I need very simple convert dxf to g only, please help?
Tweakie.CNC
9,378
Super Kitty
Re: new version mach3 no dxfimport?
Reply #1 on:
November 26, 2010, 07:02:21 AM »
I think the only way to keep the direct DXF import is to keep using the earlier version of Mach.
However I can't see any reason why you can't have both versions on the same PC and then use which ever version you choose.
kkquek
9
Reply #2 on:
November 26, 2010, 07:12:06 AM »
thank a lot
Carnoustie, Scotland
Reply #3 on:
November 26, 2010, 10:27:50 AM »
If you do as Tweakie suggests make sure you install the older version to a different directory and
Don't
install the driver or you will overwrite the newer driver and will likely have problems.
Print
Pages:
1
Go Up
« previous
next »
