Hello Guest it is September 08, 2026, 08:16:11 PM
Author Topic: Flash RU Screen  (Read 173024 times)
Re: Flash RU Screen
« Reply #20 on: May 06, 2010, 01:49:04 PM »
ok, nice to know. ;)
in this case, i have less problems !
tests continues.
Re: Flash RU Screen
« Reply #21 on: May 07, 2010, 10:31:21 AM »
New update:
1.33 New and modified Macros: RefX,RefY,RefZ, M6Start, M1001
     Some corrections to the toolchange slider
     Correction to the bottom bar
     Added Estimate time in the load screen
     Added diagnostics screen.
     Some leds can be changed by clicling on them or their label
     Added optional stop feature.
     To make an optional stop code must have 2 consucutive lines:
   M1001
        M01
     Could not do it through M01 alone because theres no optional stop led for it.
     Added rapids override button on feed override slider.
     I may change its location in the future because it does not work while part is running
There may be new bugs. Please report them
thanks
Re: Flash RU Screen
« Reply #22 on: May 07, 2010, 11:48:19 AM »
Hello,
i test, i test...
When you hit the first time a button zoom or pan or tilt,
sometimes it doesnt activate. I need to click first on the activ
view button, and after on the required view button.
I have also trouble with the wizard.
The system say that a script is slowdown the running of adobe flash player.
I need to stop the script and exit mach3 to can restart again.
This 2 problems was already in the first version.
i no found the gcode that doesnt open the last days, i will search it...
Next this evening or tomorow
Fabrice
Re: Flash RU Screen
« Reply #23 on: May 07, 2010, 12:53:31 PM »
Hello again;
it seems that the file in error was the example gcode roadrunner from Mach3.
Fabrice
Re: Flash RU Screen
« Reply #24 on: May 07, 2010, 08:35:31 PM »
Hi Fabrice
The readrunner runs fine here. I use it all the time to test.
Can you please be more specific about the wizard problem so I can reproduce it?
Like what values you are entering, in wich wizard.
Also if possible opst your xml config file.
thanks
Re: Flash RU Screen
« Reply #25 on: May 07, 2010, 10:32:31 PM »
Hello
for the wizard take Surface wizard for example.
For end X and Y value 10, step 1.
I can use any of the 5 wizards, i still have the same problem.
It is the same with entering value or without entering value
I send you a screenshot and the xml config file.
i have problem actually to attach a file to the board,
message error that this file already exist !
The roadrunner file open yet in version 1.31 and 1.33
1.31 with font loaded the roadrunner file.
Fabrice
Re: Flash RU Screen
« Reply #26 on: May 08, 2010, 02:10:37 AM »
me again,
so i test the screen now on the cnc pc.
It run under xp 32 bits , and i have not the problems
with the wizard. The wizard generate correctly the gcode.
I need now to unterstand the macros to adapt your screen
to my machine.
Loading of gcode file are also correct, running also.
Next here some news,
Can you open the MDI command field so i can test it to ?
Fabrice
Re: Flash RU Screen
« Reply #27 on: May 08, 2010, 10:42:46 AM »
Hi Fabrice,
I havent made the mdi screen yet. As soon as I have it i will share it
Regards
Re: Flash RU Screen
« Reply #28 on: May 08, 2010, 04:53:48 PM »
New Version V1.34
1.34 Corrected a bug found by Fabrice Engel.
     when a wizard was posted, the values where taken from dros without being validated.
     This caused the screen to crash when the values had never been edited.
     I have added validation, but still some combination of values may lead to crash,
     specially when generating too many lines of code.
     Corrected graphic problem with depth in straight cut wizard and list of holes in holes wizard
Re: Flash RU Screen
« Reply #29 on: May 08, 2010, 11:59:04 PM »
Morning Pablo,
thanks for correcting. So i test the wizard on the laptop.
Now it run :)
But the wizard Rect Pocket doen't open. All other 4 are ok.
I cannot add hole coordinate with the + button, but i suppose
that is the normal way to do ! ok, not so quick, i need to learn
how is the concept.
Best regards,
Fabrice
