Hello Guest it is November 13, 2026, 04:23:33 PM
Author Topic: Flash RU Screen  (Read 180726 times)
Re: Flash RU Screen
« Reply #40 on: May 31, 2010, 06:29:35 PM »
Hi fever,
Unfortunatedly I did not continue developement lately because theres no more than a couple users testing it, and for my oersonal use the screen is ok, it has what I need.
I may resume developement when I have more free time.
thanks
Re: Flash RU Screen
« Reply #41 on: May 31, 2010, 07:38:54 PM »
Hi Pablo
Very nice screen you made. Really like the look of it, and the "pop-up" keys....
 nice!
Looks just like the touchscreen that i have always wanted for my machine :o)
I'll test it as soon as I get my touchscreen hooked up to my router
I think if you continue the development, there will be a lot of new testers!
Keep up the good work!
Best regards
Borge
Denmark
Re: Flash RU Screen
« Reply #42 on: May 31, 2010, 10:19:35 PM »
yes borge is right.
this one is really good.
pls continue the work (of course when your free)
and as i asked can u attach the final working version of the screen.(least bug version)
Re: Flash RU Screen
« Reply #43 on: June 01, 2010, 07:43:37 PM »
Last version at this time is`1.35.
I upload them here when I make some significant changes.
The bugs fixes and changes are doccumented in the VersionInfo.txt file.
I would like to know what bugs you are referring to so I can try to fix them
Regards
Re: Flash RU Screen
« Reply #44 on: June 16, 2010, 11:41:01 PM »
Hello all,
ok ok i know, it is Worldcup in South Africa,, but as somebody the opportunity
to test more the screen ?
I apologise, i have no lot of time actually to continu, but il like this screen, found good ideas
inside, and i think that Pablo need more feedback from our community
to help him in the improvement.
What is your status ?
Fabrice
Re: Flash RU Screen
« Reply #45 on: August 22, 2010, 01:24:26 PM »
New version v1.37
1.37 GCode now loads asynchronous to allow for long programs without crashing mach
        Up and down code arrows now have a different behavior to traverse long programs more easily
Regards
Pablo
New Version v1.38
« Reply #46 on: August 22, 2010, 08:23:33 PM »
1.38 Added the Walk macro in the load screen to preview the work limits (It previews at the current z level, so take care with clamps)
Update V1.39
« Reply #47 on: August 22, 2010, 10:23:21 PM »
1.39 Added Stop button to interrupt walk. Added about window (the screen version is now shown there)
New upgrade V1.40
« Reply #48 on: September 01, 2010, 06:42:56 PM »
V1.40
1.40 Optional stop led was reversed. Corrected.
        Wizards now inform in the status line Current Pass and Previous pass time. For this M1002 and M1003 are implemented
         Corrected a new bug that prevented from scrolling the code window in wizards
         Added a button to turn on/off cross hair. Jog mode is removed and the mode now is changed by touching its led
         Added the rpm/feed calculator informing sfm and chipload. the calculator is opened by pushing the F button.
         A new wizard button "probing" is still not functional. Im working on that.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Flash RU Screen
« Reply #49 on: September 01, 2010, 10:26:38 PM »
I will have time to test, one thing I would like to mention is you must be running Flash 9 or later, we have not updated the plugin for Flash 10 yet.
Please run the following if you have Flash 10 or greater, also you must Publish for Flash 8 in Flash Pro:
First run: FlashUtil10h_ActiveX.exe
Then run: flashplayer9r277_winax.exe
« Last Edit: September 01, 2010, 10:32:04 PM by zealous »
