Hello Guest it is November 13, 2026, 04:34:51 PM
Author Topic: Flash RU Screen  (Read 180736 times)
Re: Flash RU Screen
« Reply #30 on: May 09, 2010, 10:36:31 AM »
Hello,
so i am trying to replace some macros (yes trying because i am not able to understand each macro).
I was able to adapt the RefAll macros (because i copied the original orders), but it is an other
way for Probe macro. I use the screen Aqua, that is provided with a macro for the Probe Z high.
Can you explain how the part Probe run. (Initial offset and Z-Touch).
That can be helpfull for me to adapt the macro from Aqua.
A suggestion, if the probe screen is open, you hide a part of the status line.
Can you please dock higher the flash screen ?
Fabrice
Re: Flash RU Screen
« Reply #31 on: May 09, 2010, 11:27:57 AM »
Hi fabrice,
the auto zero bueeon and probe slider are actually for zeroing the part (maybe I used the wrong name)
I have a fixed zero touch plate installed in my machine, and I do manual tool change.
So when I put the first tool, I use the probe slider to zero it. When it is ready where i want it to be, I press the "initial tool offset" button and the tool travels to the fixed plate and measures.
Then each time I change a tool, I dont have to worry for the z zero. I just put it and press the auto zero button. The tool travels to the fixed plate and measures, and addapts the z zero according to the first tool.
1) Put first tool.
2) Set X,Y,Z manually or with the probe slider
3) Press the "initial tool measure" button to measure the tool against fixed plate
4) Run program
5) When toolchange is requested, change tool manually and press auto zero.
Hope that clarifies. I will correct the slider problem you reported
regards
Re: Flash RU Screen
« Reply #32 on: May 12, 2010, 05:47:15 AM »
Hello Pablo,
i have some days off so i will print the macro on paper and learn a bit (little :)
I hope i reach the goal, because i want to use your screen for my
hobby, and it is important for a good running of the cnc.
What is the fonction of the Lamp ?
best regards,
Fabrice
Re: Flash RU Screen
« Reply #33 on: May 12, 2010, 10:03:01 AM »
Hi fabrice,
I installed led bars in my router gantry. The lamp button is for turning them on and off.
i will try to make that button customizable in the future. Right now it toggles output 6
Regarsd
Re: Flash RU Screen
« Reply #34 on: May 13, 2010, 01:32:09 AM »
Morning from France,
i reach to implement the macro of Ernis (i suppose) for the Zeroing of the axe Z.
I use a mobile gauge, so x and y are never the same.
Is the field where you put the initial value offset Z the userDRO(2055) ?
Because i like to use this field as manual input of the high of the gauge
(actually it is hardcoded in the macro with a value 20mm)
So i can adapt the macro so that anyone can use it with different gauge.
I miss also the fonction key F5 to start/stop the spindle.
With no flash screen it was possible to modify the screen set, but
i have no idea how to change it in your flashscreen.
Thank's
Fabrice
Re: Flash RU Screen
« Reply #35 on: May 17, 2010, 10:24:06 AM »
Hi Fabrice,
Sorry for the delay.
I store in DRO 2055 the offset of the first tool. The oneobtained when you measure using the "measure initial offset" button.
Here you have a list of the leds and dros I have defined so far.
I will see if I can implement the F5 funstion in the future.
Regards
Re: Flash RU Screen
« Reply #36 on: May 17, 2010, 10:40:03 AM »
Thanks for the documentation.
I will look at.
Fabrice
Re: Flash RU Screen
« Reply #37 on: May 19, 2010, 10:22:02 PM »
1.35 Changed the "Go Zero" button for "Go Pos".
     The new button opens a slider that allows going to zero or any other position.
     Added macro: GoCoord
     RUCONFIG: New GoZeroTimeout and GoCoordTimeout parameters
    Some work on optional stop slider
Im working on a new wizard to cut trajectories and shapes
Regards
« Last Edit: May 19, 2010, 10:37:56 PM by elpablito »
Re: Flash RU Screen
« Reply #38 on: May 22, 2010, 04:20:55 AM »
Good Morning Pablo,
i test again you new version. Nice thing with the Go option.
A question, do you manage the limit display in the Load screen ?
because the information of the size limit of a gcode file  are not displayed.
I wish you a nice week-end,
Fabrice
Re: Flash RU Screen
« Reply #39 on: May 31, 2010, 10:38:04 AM »
ohh i was looking at wrong place for this screen.
Thanks for sharing pablo.
i will try this on my 17'' touch screen.i already have ultimate screen,its quite good build.
Yours also seems good.can you update the final locked down version of the screen.
Regards
