Hello
Guest
it is
September 02, 2026, 02:33:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
3d Digitizing PlugIn version 3.0
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: 3d Digitizing PlugIn version 3.0 (Read 34032 times)
Keith
187
on:
October 08, 2006, 12:54:53 PM »
What is this 'plug in'? I'm just getting around to experimenting with a probe. Seems like it might be something I want. Does it work with the 'digitizing wizard' in 'Wizards'(which I can't make heads or tails of). Any other tutorials on using a probe would be nice. Info is slim out there.-Keith
Brian Barker
3,860
Re: 3d Digitizing PlugIn version 3.0
Reply #1 on:
October 09, 2006, 08:55:27 PM »
Look for the thread that talks about it and you should be okay
To get it working you need to go to config plugin and enable it. After you do that close mach 3 and reopen it. you should see "probe" by help on the menu bar.
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Keith
187
Reply #2 on:
October 10, 2006, 08:34:06 AM »
Hi and thanks Brian. I grabbed that plug-in but it saves as a text file not a .dll. Anyway I put it in the 'plug in' folder in Mach3 but when I try to 'enable', it doesn't come up as a potential plug-in (I suppose)because of the extension. Should I rename it as a .dll?Thanks-Keith
Brian Barker
3,860
Reply #3 on:
October 12, 2006, 06:18:16 AM »
Yes it should bew a .dll . if it is not... hhmmm was it a .txt when you got it? if it is a .m3p file just bouble click it and it should install
www.machsupport.com
Keith
187
Reply #4 on:
October 12, 2006, 07:59:47 AM »
Thanks,yes it is an .m3p (but if you view it on a Mac which is where I download stuff on,it comes up as text characters)and I just installed that into the Mach plug in folder on my controller machine. All is well now. Thanks,Keith
Keith
187
Reply #5 on:
October 12, 2006, 03:15:17 PM »
Wait,spoke too soon,no matter where I put that file,a double click just brings it up in 'notepad' as text.-Keith
Keith
187
Reply #6 on:
October 14, 2006, 09:55:58 AM »
I downloaded on my Mac. Maybe the Mac puts an the extra extension(it reads 'Probing-1.m3p.txt',saved to desktop).I then eliminate the .txt extension and rename it with just the .m3p extension. Transfer it to my machine that's controlling the cnc. Double click and still it opens in 'notepad'.-Keith
Reply #7 on:
October 14, 2006, 01:14:55 PM »
Maybe your file association for .m3p has been set to open with notepad, try removing the association (if there is one) and see if it works correctly.
Keith
187
Reply #8 on:
October 15, 2006, 04:08:33 PM »
The machine is indeed suggesting it to be open with 'notepad'. I can 're-associate' the file but I'm not sure what 'association' is appropriate for a self extracting file such as this.-Keith
Reply #9 on:
October 15, 2006, 04:12:23 PM »
Heres a screenshot of what the association should be I think.
Print
Pages:
1
2
Go Up
« previous
next »
