Hello Guest it is October 24, 2026, 01:56:25 PM
Author Topic: 3d Digitizing PlugIn version 3.0  (Read 34518 times)
Offline Keith
  •  187 187
Re: 3d Digitizing PlugIn version 3.0
« Reply #10 on: October 15, 2006, 04:42:12 PM »
Oof,for some reason ,as global moderator,I can't download posted attachments(or post myself). If I could trouble you to email that,it would be appreciated,Keith
« Reply #11 on: October 15, 2006, 04:47:03 PM »
just sent it.
hood
Offline Keith
  •  187 187
« Reply #12 on: October 15, 2006, 05:43:17 PM »
Thanks Hood. I managed to get the folder options to look like the screen shot but in doing so ,it asks for an 'action' to take place. I said:"open". Not sure if that's right. Still opened in notebook. When I'm 'clicking' on this file, should it be residing in the plug in folder? Anyway,I tried it in the folder and outside the folder.-Keith
Offline Keith
  •  187 187
« Reply #13 on: October 15, 2006, 05:52:01 PM »
Ok,I got it,but it didn't happen automatically. Once I told 'folders' to open that type of file with M3 plug-in control,I then went to where it was and manually did an 'open with' and used that same control and it extracted .Thanks for getting me started. -Keith
Offline Keith
  •  187 187
« Reply #14 on: October 16, 2006, 08:59:48 AM »
After all that,everything went kookie. I often got an error code from Mach on start-up and would have to open Mach a second time to not get the error.Last night ,all I got was this error. I was using 1.95x.So this morning I went back to 1.84 and that came up nicely with no problems.However,I notice LazyCam is not there and the 'plug-in enable' is gone from the menu. Does this only work with the on-going ver2.0? Is 2.0 pretty stable? By the way,since I already had the probing file in it's .dll form,I thought I'd put it in the plug-in folder that way. Not sure if that's ok.-Keith
« Reply #15 on: October 16, 2006, 02:00:58 PM »
Sorry Keith, dont have any answers for you as I have never used the plugin, maybe Brian or Art will be of more help to you.
« Reply #16 on: October 21, 2006, 03:41:17 PM »
You should be okay with the new Rev2.xx
Brian
www.newfangledsolutions.com
www.machsupport.com
