Hello Guest it is September 02, 2026, 02:32:06 PM
Author Topic: 3d Digitizing PlugIn version 3.0  (Read 34028 times)
Offline Keith
  •  187 187
« on: October 08, 2006, 12:54:53 PM »
What is this 'plug in'? I'm just getting around to experimenting with a probe. Seems like it might be something I want. Does it work with the 'digitizing wizard' in 'Wizards'(which I can't make heads or tails of). Any other tutorials on using a probe would be nice. Info is slim out there.-Keith
Re: 3d Digitizing PlugIn version 3.0
« Reply #1 on: October 09, 2006, 08:55:27 PM »
Look for the thread that talks about it and you should be okay :)
To get it working you need to go to config plugin and enable it. After you do that close mach 3 and reopen it. you should see "probe"  by help on the menu bar.
www.newfangledsolutions.com
www.machsupport.com
Offline Keith
  •  187 187
« Reply #2 on: October 10, 2006, 08:34:06 AM »
Hi and thanks Brian. I grabbed that plug-in but it saves as a text file not a .dll. Anyway I put it in the 'plug in' folder in Mach3 but when I try to 'enable', it doesn't come up as a potential plug-in (I suppose)because of the extension. Should I rename it as a .dll?Thanks-Keith
« Reply #3 on: October 12, 2006, 06:18:16 AM »
Yes it should bew a .dll . if it is not... hhmmm was it a .txt when you got it? if it is a .m3p file just bouble click it and it should install
www.machsupport.com
Offline Keith
  •  187 187
« Reply #4 on: October 12, 2006, 07:59:47 AM »
Thanks,yes it is an .m3p (but if you view it on a Mac which is where I download stuff on,it comes up as text characters)and I just installed that into the Mach plug in folder on my controller machine. All is well now. Thanks,Keith
Offline Keith
  •  187 187
« Reply #5 on: October 12, 2006, 03:15:17 PM »
Wait,spoke too soon,no matter where I put that file,a double click just brings it up in 'notepad' as text.-Keith
Offline Keith
  •  187 187
« Reply #6 on: October 14, 2006, 09:55:58 AM »
I downloaded on my Mac. Maybe the Mac puts an the extra extension(it reads 'Probing-1.m3p.txt',saved to desktop).I then eliminate the .txt extension and rename it with just the .m3p extension. Transfer it to my machine that's controlling the cnc. Double click and still it opens in 'notepad'.-Keith
« Reply #7 on: October 14, 2006, 01:14:55 PM »
Maybe your file association for .m3p has been set to open with notepad, try removing the association (if there is one) and see if it works correctly.
Offline Keith
  •  187 187
« Reply #8 on: October 15, 2006, 04:08:33 PM »
The machine is indeed suggesting it to be open with 'notepad'. I can 're-associate' the file but I'm not sure what 'association' is appropriate for a self extracting file such as this.-Keith
« Reply #9 on: October 15, 2006, 04:12:23 PM »
Heres a screenshot of what the association should be I think.
