Hello
Guest
it is
November 13, 2026, 12:29:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Softlimits question
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Softlimits question (Read 29814 times)
dacostad
48
Softlimits question
on:
February 16, 2010, 10:00:27 AM »
I use softlimits on my Novakon Mill and whenever I load Mach 3 I get a "Softlimits System Movement Aborted" message in the status bar before I do anything including referencing the mill.
Can anyone tell me what this means and why is it occurring?
David
M250cnc
591
Re: Softlimits question
Reply #1 on:
February 16, 2010, 11:00:54 AM »
David at the moment i can only think that you have a move in the Initialisation script, i have never seen that problem asked before.
The string is under CONFIG, GENERAL CONFIG...
Phil
dacostad
48
Reply #2 on:
February 16, 2010, 11:06:53 AM »
Nope, just G80.
David
Overloaded
4,923
Reply #3 on:
February 16, 2010, 11:19:59 AM »
Hi Dave,
Anything in the Macro Pump ?
Russ
M250cnc
591
Reply #4 on:
February 16, 2010, 11:21:11 AM »
Good answer Russ
Phil
Overloaded
4,923
Reply #5 on:
February 16, 2010, 11:27:25 AM »
Thanks Phil.
Dave, if you're not sure about the Pump, go to Gen. Config. and uncheck Run Macro Pump if it's checked, then restart and see if it clears up.
Russ
dacostad
48
Reply #6 on:
February 16, 2010, 12:45:17 PM »
Hi Russ, I already have macro pump unchecked, so it is not that.
David
Carnoustie, Scotland
Reply #7 on:
February 16, 2010, 01:02:16 PM »
You either have your soflimits set wrong or for some reason you have moved outwith them when they were disabled and now you will have to move back before you can enable them.
What do you have the Soft Limits set as?
dacostad
48
Reply #8 on:
February 16, 2010, 01:14:46 PM »
y max 13 min 0
x max 5.9 min 0
z max 0 min -11.35
I get the message when I start up Mach 3, if I clear it, I only see it again if I move to one of the softlimit limits which is what I would expect.
David
Reply #9 on:
February 16, 2010, 01:15:33 PM »
Can you attach your xml please.
Print
Pages:
1
2
Go Up
« previous
next »
