Hello Guest it is November 13, 2026, 12:14:20 PM
Author Topic: Softlimits question  (Read 29805 times)
Softlimits question
« on: February 16, 2010, 10:00:27 AM »
I use softlimits on my Novakon Mill and whenever I load Mach 3 I get a "Softlimits System Movement Aborted" message in the status bar before I do anything  including referencing the mill.
Can anyone tell me what this means and why is it occurring?
David
Re: Softlimits question
« Reply #1 on: February 16, 2010, 11:00:54 AM »
David at the moment i can only think that you have a move in the Initialisation script, i have never seen that problem asked before.
The string is under CONFIG, GENERAL CONFIG...
Phil
« Reply #2 on: February 16, 2010, 11:06:53 AM »
Nope, just G80.
David
« Reply #3 on: February 16, 2010, 11:19:59 AM »
Hi Dave,
 Anything in the Macro Pump ?
Russ
« Reply #4 on: February 16, 2010, 11:21:11 AM »
Good answer Russ  ;D
Phil
« Reply #5 on: February 16, 2010, 11:27:25 AM »
Thanks Phil.
Dave, if you're not sure about the Pump, go to Gen. Config. and uncheck Run Macro Pump if it's checked, then restart and see if it clears up.
Russ
« Reply #6 on: February 16, 2010, 12:45:17 PM »
Hi Russ, I already have macro pump unchecked, so it is not that.
David
« Reply #7 on: February 16, 2010, 01:02:16 PM »
You either have your soflimits set wrong or for some reason you have moved outwith them when they were disabled and now you will have to move back before you can enable them.
What do you have the Soft Limits set as?
« Reply #8 on: February 16, 2010, 01:14:46 PM »
y max 13 min 0
x max 5.9 min 0
z max 0 min -11.35
I get the message when I start up Mach 3,  if I clear it, I only see it again if I move to one of the softlimit limits which is what I would expect.
David
« Reply #9 on: February 16, 2010, 01:15:33 PM »
Can you attach your xml please.
