Hello Guest it is November 13, 2026, 10:05:47 AM
Author Topic: Settings or machine problem  (Read 41633 times)
Re: Settings or machine problem
« Reply #20 on: December 05, 2006, 10:25:30 PM »
Can you tell me what to check on the gecko driver in this picture, I mean I want you to tell me where put the one end of the multimeter, Put it  here on (blank) and the other end on (blank) and you should get this voltage.  ;D
Greg
"Ideas have consequence" Ravi Zaccharias
« Reply #21 on: December 05, 2006, 11:13:47 PM »
Put your Negative lead on the gecko Power Ground pin and your positive on the 24-80 VDC pin. I watched the video, sounds like you are trying to run it too fast to me.
« Reply #22 on: December 08, 2006, 06:48:53 PM »
The voltage for the stepper drivers while running is 35.2v. its the same while idle.
If I am running it to fast why does the K2 website say I can run it at 150 ipm? ???
This is a very weird problem because it will run just fine for one program and not for an other, what should I set my velocity and acceleration at?  I have dropped it very low before and it still kept messing up?
Thanks, :P
Greg
« Reply #23 on: December 08, 2006, 08:35:46 PM »
Hi Greg,
  I have sent you a personal message.
« Reply #24 on: December 08, 2006, 10:49:59 PM »
I talked to Chaoticone and he gave me some great advice, we talked quite a bit about many possible problems and I think we have a good handle on what the problem is.  We will have to see, I have to run some more programs to see if it has stops freezing up and missing steps.
Thanks for the help ;D
Greg
