Hello Guest it is October 21, 2026, 02:04:01 AM
Author Topic: Stepper motor lubrication?  (Read 17543 times)
Offline NormB
  •  169 169
  • Norm
« on: January 19, 2010, 01:11:28 PM »
Do stepper motors need lubrication?
Re: Stepper motor lubrication?
« Reply #1 on: January 19, 2010, 01:39:11 PM »
NormB,
The internal bearings have lubrication on them. They are basicaly a sealed unit and should not be taken apart.
So from what i can see i quess not. Never read anything to the contrary.
Offline NormB
  •  169 169
  • Norm
« Reply #2 on: January 19, 2010, 01:43:17 PM »
I thought that might be the case but just had to ask.  Usually if lubrication is needed a port or some entry is provided to lubricate with.  thank you for the response.
« Reply #3 on: January 19, 2010, 01:48:57 PM »
FWIW,
I took a few very old steppers apart and the bearing grease was still good. Good question though and you may want to do some internet searches and see what you find.
« Reply #4 on: January 19, 2010, 04:02:50 PM »
Bearings on motors are what they call "sealed for life", so once you start hearing noise you know your bearings need replaced.
