Hello Guest it is November 13, 2026, 06:16:04 AM
Author Topic: Lathe feed rate overide not working?  (Read 13287 times)
« on: January 07, 2010, 02:33:34 PM »
Hi everyone,
I have just revamped my "all in one" lathe screen and i found the feedrate override% values change in the DRO but during a cut it does not affect the feed rate
anyone else have the same problem?
my new all in one screen set can be found here
http://www.machsupport.com/forum/index.php/topic,13544.msg88912.html#msg88912
thanks
Friedrich
Re: Lathe feed rate overide not working?
« Reply #1 on: January 07, 2010, 05:52:19 PM »
I think it works fine for me but I am not using the latest version of Mach, I will try and remember to make sure tomorrow.
« Reply #2 on: January 08, 2010, 05:06:39 AM »
Just tested here and FRO works fine with both G95 and G94 but I am using an older version on the lathe (021) and also the SmoothStepper. Maybe RC or Rich will be able to test for you with the parallel Port.
« Reply #3 on: January 08, 2010, 09:12:32 AM »
Thanks Hood at least i know the screenset is ok
« Reply #4 on: January 08, 2010, 09:21:44 AM »
ah, didnt try with your screenset, sorry, will try later if I get a chance, kind of busy with the lathe at the moment
« Reply #5 on: January 08, 2010, 09:49:32 AM »
ok tried your screenset and its working :)
