Hello Guest it is November 12, 2026, 12:31:36 AM
Author Topic: Cool New Feature  (Read 24131 times)
Cool New Feature
« on: December 27, 2009, 07:04:03 AM »
Hi Klaus,
In the top right hand corner is the box displaying the properties.
Would it be possible to add the two figures together so that a dro displays LEFT EDGE + WIDTH & TOP EDGE + HEIGHT
This would then make a total of 6 dro's
Reasoning i position my box at the required top and left edges but i want the box to finish at the screen edge
Maybe it could be that you could fill in the right edge and this would calculate the width etc
Phil
Re: Cool New Feature
« Reply #1 on: December 28, 2009, 04:31:58 AM »
Hi Phil,
I implemented your suggestion in version V1.35 which can be downloaded from my site. When you change left, right, top or bottom parameter, the width / height is calculated. If width or height is < 2, the entry is ignored and an error is thrown.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: December 28, 2009, 06:07:35 AM »
Hi Klaus,
You are truly amazing amazing.
Phil
