Hello Guest it is November 22, 2026, 09:51:53 AM
Author Topic: nedd program help  (Read 10998 times)
nedd program help
« on: November 09, 2009, 12:10:17 PM »
guys,
i need help finding out whats going on with my program...I designed the part in bobcadcam V21.  I then uesd the mach1 postprocessor from the mach site to write the program.  After i start the program it goes to line 2861 and says something about the radius differing.  the txt code is attached
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: nedd program help
« Reply #1 on: November 09, 2009, 12:21:38 PM »
Hi, Krymis
In General Config, Check your IJ settings, Loads fine hear.
Chip
« Reply #2 on: November 09, 2009, 12:54:27 PM »
chip,
thanks that worked.  What does that IJ mode in absolute or inc. have to do with making it work? Also how can I easily add in an Optional stop at every z move to manually lower my z axis until the new z axis is plates are done?
