Hello
Guest
it is
November 13, 2026, 10:21:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
THC300 arc voltage
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: THC300 arc voltage (Read 10894 times)
Kees Holland
6
THC300 arc voltage
on:
August 24, 2006, 03:12:12 PM »
What is the voltage range to adjust the arc distance while cutting.
Best regards, Kees
Brian Barker
3,860
Re: THC300 arc voltage
Reply #1 on:
August 25, 2006, 10:35:36 AM »
You may have to mail Jim C for that one
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
jcullins
11
Reply #2 on:
September 25, 2006, 01:46:27 PM »
It will adjust from about 200v down to 50 v on the older units.
I have added a switch and resistor make it adjust lower for fine consumables.
If you what the mod email me off list and I will send it to you.
JimC
Print
Pages:
1
Go Up
« previous
next »
