Hello
Guest
it is
November 22, 2026, 08:25:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Interface bwteen the parallel ports and Servo motors
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Interface bwteen the parallel ports and Servo motors (Read 17034 times)
ericma
on:
August 17, 2006, 02:43:34 PM »
Friends:
I need a breakout board to interface the parallel port and Yaskawa servo motors (Amplifiers).
I am working on a project of 5 axis CNC router.
Is any commercial breakout board available?
Brian Barker
3,860
Re: Interface bwteen the parallel ports and Servo motors
Reply #1 on:
August 17, 2006, 07:10:40 PM »
I think Bob C has a board that will plug into the 2nd p port..
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
ericma
Reply #2 on:
August 18, 2006, 12:52:12 PM »
I am unable to contact with Bob C. He is alway on vacation?
do you know his phone number?
Brian Barker
3,860
Reply #3 on:
August 18, 2006, 07:59:36 PM »
I don't know his number
But any of the breakout boards ahould work.. you just need to have two of them
you can set up a second port in Mach and it will use the same hardware
PMXD has a nice setup as well as cnc4pc
Hope that helps
Brian
www.machsupport.com
ericma
Reply #4 on:
August 23, 2006, 03:31:17 PM »
I will order the CNC4PC board.
Print
Pages:
1
Go Up
« previous
next »
