Hello Guest it is November 22, 2026, 08:25:50 AM
Author Topic: Interface bwteen the parallel ports and Servo motors  (Read 17037 times)
ericma
« on: August 17, 2006, 02:43:34 PM »
Friends:
I need a breakout board to interface the parallel port and Yaskawa servo motors (Amplifiers).
I am working on a project of 5 axis CNC router.
Is any commercial breakout board available?
Re: Interface bwteen the parallel ports and Servo motors
« Reply #1 on: August 17, 2006, 07:10:40 PM »
I think Bob C has a board that will plug into the 2nd p port..
www.newfangledsolutions.com
www.machsupport.com
ericma
« Reply #2 on: August 18, 2006, 12:52:12 PM »
I am unable to contact with  Bob C. He is alway on vacation?
do you know his phone number?
« Reply #3 on: August 18, 2006, 07:59:36 PM »
I don't know his number :( But any of the breakout boards ahould work.. you just need to have two of them :) you can set up a second port in Mach and it will use the same hardware :o
PMXD has a nice setup as well as cnc4pc
Hope that helps
Brian
www.machsupport.com
ericma
« Reply #4 on: August 23, 2006, 03:31:17 PM »
I will order the CNC4PC board.
