Hello
Guest
it is
November 13, 2026, 08:11:22 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Is it possible to turn the screen display 180 degrees?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Is it possible to turn the screen display 180 degrees? (Read 12736 times)
Marv Frankel
7
on:
May 14, 2009, 07:35:18 PM »
Guys,
I'm having a problem dealing with the screen display being 180 degrees from the way the mill cuts. It's driving me a little bananas. Can either the screen or the cutting be turned?
Marv Frankel
Los Angeles
Chaoticone
5,624
Precision Chaos
Re: Is it possible to turn the screen display 180 degrees?
Reply #1 on:
May 14, 2009, 08:14:38 PM »
That is decided by your axis. Looking at the toolpath window, the x will run left to right and the y will be top to bottom.
If you could see the things I have in my head, you would be laughing too.
MachineMaster
150
Reply #2 on:
May 15, 2009, 01:18:01 AM »
If you look at the mill as having a stationary table and all movement as done by the quill does the quill follow the display?
Graham Waterworth
2,785
Yorkshire Dales, England
Reply #3 on:
May 15, 2009, 02:39:49 AM »
Have a look at this post and tell us if your machine is working this way.
http://www.machsupport.com/forum/index.php/topic,1725.msg9977.html#msg9977
Graham
Print
Pages:
1
Go Up
« previous
next »
