Hello Guest it is November 13, 2026, 07:58:04 PM
Author Topic: Is it possible to turn the screen display 180 degrees?  (Read 12734 times)
« on: May 14, 2009, 07:35:18 PM »
          Guys,
              I'm having a problem dealing with the screen display being 180 degrees from the way the mill cuts. It's driving me a little bananas. Can either the screen or the cutting be turned?
Marv Frankel
Los Angeles
Re: Is it possible to turn the screen display 180 degrees?
« Reply #1 on: May 14, 2009, 08:14:38 PM »
That is decided by your axis. Looking at the toolpath window, the x will run left to right and the y will be top to bottom.
« Reply #2 on: May 15, 2009, 01:18:01 AM »
If you look at the mill as having a stationary table and all movement as done by the quill does the quill follow the display?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: May 15, 2009, 02:39:49 AM »
Have a look at this post and tell us if your machine is working this way.
http://www.machsupport.com/forum/index.php/topic,1725.msg9977.html#msg9977
Graham
