Hello
Guest
it is
November 19, 2026, 03:12:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
This program will not run on Mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: This program will not run on Mach3 (Read 15224 times)
bfairey
40
on:
February 27, 2009, 02:20:00 PM »
Please see attached code
Brian.
Code:
[Select]
Tweakie.CNC
9,378
Super Kitty
Re: This program will not run on Mach3
Reply #1 on:
February 28, 2009, 01:47:01 AM »
You have not succeeded in attaching the code Brian.
bfairey
40
Reply #2 on:
February 28, 2009, 06:42:43 AM »
Thanks Tweaky but where do I attach the file?
Brian.
Tweakie.CNC
9,378
Super Kitty
Reply #3 on:
February 28, 2009, 06:54:02 AM »
Hi Brian,
Click on 'Additional Options' then see 'Attach' use the 'Browse' to select the file (note only certain file types are allowed) then post.
bfairey
40
Reply #4 on:
February 28, 2009, 10:06:07 AM »
Please see what you can make of this
Brian.
ger21
6,295
Reply #5 on:
February 28, 2009, 10:30:54 AM »
You need to attach the g-code, not the .dxf
Tweakie.CNC
9,378
Super Kitty
Reply #6 on:
February 28, 2009, 11:28:42 AM »
Hi Brian,
I don't know if you are cutting the part or engraving/drawing it. Assuming the profile was to be engraved I have converted your dxf to GCode (using Vistool 6) and the file is attached for you to look at.
Print
Pages:
1
Go Up
« previous
next »
