Hello Guest it is November 19, 2026, 03:12:38 PM
Author Topic: This program will not run on Mach3  (Read 15225 times)
« on: February 27, 2009, 02:20:00 PM »
Please see attached code
Brian.
Code: [Select]
  •  9,378 9,378
Re: This program will not run on Mach3
« Reply #1 on: February 28, 2009, 01:47:01 AM »
You have not succeeded in attaching the code Brian.
« Reply #2 on: February 28, 2009, 06:42:43 AM »
Thanks Tweaky but where do I attach the file?
Brian.
  •  9,378 9,378
« Reply #3 on: February 28, 2009, 06:54:02 AM »
Hi Brian,
Click on 'Additional Options' then see 'Attach' use the 'Browse' to select the file (note only certain file types are allowed) then post.
« Reply #4 on: February 28, 2009, 10:06:07 AM »
Please see what you can make of this
Brian.
« Reply #5 on: February 28, 2009, 10:30:54 AM »
You need to attach the g-code, not the .dxf
  •  9,378 9,378
« Reply #6 on: February 28, 2009, 11:28:42 AM »
Hi Brian,
I don't know if you are cutting the part or engraving/drawing it. Assuming the profile was to be engraved I have converted your dxf to GCode (using Vistool 6) and the file is attached for you to look at.
