Hello Guest it is November 11, 2026, 08:54:53 PM
Author Topic: Problem with outputs  (Read 11612 times)
Offline Robhi
  •  138 138
« on: February 14, 2009, 10:24:12 AM »
Hello,
I have a problem with the output 2 . I have a the output# 1 enabled , port# set to 1 and pin Number set to 1 too, the spindle work well.
But the output# 2 enabled , port# set to 1 and pin Number set to 14 ,nothing works..all is wired as in the output # 1, nothing changes but it does not work..
I use breakout board campbell.. and I use the same relay , but only one that works...
Did I  do something wrong? I have tried to do the same with output#3, but I had the same result...
Could I have your help?
thanks in advance
Robhi
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Problem with outputs
« Reply #1 on: February 14, 2009, 11:56:25 AM »
Hi, Robhi
What are you trying to turn on, Have you used the appropriate M-code to turn it on & off ?.
Have you tried changing the Active Low state in ports & pins ?.
Chip
Offline Robhi
  •  138 138
« Reply #2 on: February 14, 2009, 03:10:43 PM »
Hi everybody , hi Chip :) :)
Promlem is solved..
thanks for your replay, I try to turn a vaccum on and off. I did use the appropriate M.code.
Problem is solved.. the problem was that I reversed the wires of in the input I just reversed them and everything is OK.
thanks Chip and for all you. :)
Robhi
