Hello
Guest
it is
November 13, 2026, 09:22:02 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
CAN SOMEBODY HELP ME ?
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: CAN SOMEBODY HELP ME ? (Read 44594 times)
sh.y
12
on:
January 14, 2009, 09:30:21 AM »
Hi everybody ,
I'm new user . I bought a cnc kit with 4 axis ,connect everything ,setup mach3 like the toturial video and when i pressed RESET i got error "estop button pressed" i go to "input signals" "enable estop" change it to red and hit apply , try again to hit RESET and he says again this error "estop button pressed" i saw that mach3 automatically changed the enable estop to green
i don't have actually e-stop .
I will be very happy if somebody can help me !
Logged
Chip
2,055
Gainesville Florida USA
Re: CAN SOMEBODY HELP ME ?
Reply #1 on:
January 14, 2009, 09:54:19 AM »
Hi, Sh.y
Set the Pin # to "0" should fix it, Don't forget the "Apply".
Chip
Logged
sh.y
12
Reply #2 on:
January 14, 2009, 10:55:26 AM »
Thanks Chip but
the pin # is 0 and the result is the same - the sistem automatically
change it the ENABLE ESTOP to green.
Logged
Chip
2,055
Reply #3 on:
January 14, 2009, 12:04:15 PM »
Hi, Sh.y
Your saying that if you click on Reset it still flashes Red, What version are you using.
E-Stop will all-ways be Green (Checked) in Ports & Pins, With 0 in pin # you should be able to Reset, Try checking the Emulated box and Port # to 0 also.
Chip
Logged
sh.y
12
Reply #4 on:
January 14, 2009, 05:00:38 PM »
you are right Chip ! but i have another problem :
WHEN THE "RESET" FLASHING THE MESSAGE "ESTOP BUTTON PRESS"
APPEAR AND I HEAR THE MOTORS (TURN ON) AND WHEN I HIT "RESET" EVRYTHING
IS OK.(NO ERROR ) BUT I DON'T HEAR THE MOTORS (TURN OFF) AND THE
MOTORS NOT MOVE AT ALL (THE NUMBER ON THE SCREEN MOVE WHEN I PLAY WITH
THE ARROWS)
where i wrong ?
Logged
Chip
2,055
Reply #5 on:
January 15, 2009, 12:30:52 PM »
Hi, Sh.y
Post your Mach3Mill.xml file, It's should be located in C:\Mach3 folder, Make a copy of it and rename to ShyMach3Mill.xml.
Give us a little more info on your setup, Re-check your Ports & pin settings, Motor Outputs.
Chip
Logged
sh.y
12
Reply #6 on:
January 15, 2009, 03:49:13 PM »
Thanks Chip for your help i'm appreciate !
i attach the file .
Logged
Carnoustie, Scotland
Reply #7 on:
January 15, 2009, 03:57:57 PM »
You have attached the wrong file, what you have there is the exe, you need to look for a file like circled in the pic.
Logged
sh.y
12
Reply #8 on:
January 15, 2009, 04:06:47 PM »
sorry Chip
i hopes that i attach now the right file .
Logged
sh.y
12
Reply #9 on:
January 15, 2009, 04:10:10 PM »
oh! Hood thaks for your attention .
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
