Hello Guest it is November 13, 2026, 10:49:43 AM
Author Topic: ports and pins  (Read 125851 times)
ports and pins
« on: December 18, 2008, 09:05:56 PM »
School goes on.....I have a home built all-leadscrew 3-axis 24" x 48" cnc router w/ Xylotex steppers and I just bought an optical breakout board through which I want to run limit switches. I have wired all the switches together using the NC (normally closed) pin, put 5 VDC through the switches, and hooked it to opening #15 on the board. I then went to the ports and pins input section and activated the x, y, and z plus and minuses, and entered pin #15 for all of them. When I turn everything on and trip a limit switch, nothing happens and none of the LEDs light up on the diagnostics page. Anyone know what I'm doing wrong?
Also, when I use VCarvePro to calculate a toolpath, it asks me what version of Mach 3 I want to use for the postprocessor, and it has 4 choices (Mach 3 Arcs, Mach 3 Line, etc.) How do I know which version I have?
Thanx again, Bob
« Last Edit: December 18, 2008, 09:12:31 PM by rabphxaz »
Re: ports and pins
« Reply #1 on: December 19, 2008, 01:56:40 AM »
It may be the case that your BOB requires the Input pin to be grounded through the switches, what make is it?. As for the PP afraid I cant help other than saying there are not different versions of Mach such as Mach Arc etc, I would imagine a quick email to Vectric would give the answer on which is most suited.
Re: ports and pins
« Reply #2 on: December 19, 2008, 01:18:31 PM »
Reply to Hood
Re: ports and pins
« Reply #3 on: December 19, 2008, 01:28:15 PM »
Hood -- I see you're online; I'm trying to attach a wiring diagram but am having trouble. Hang in there. My last email wasn't posted but an attachment was, so it might be confusing. I thought if I could post the wiring diagram and the email I sent to the guy who provided the BOB you might be able to help me with it. I'll try again. Thanks, Bob
Re: ports and pins
« Reply #4 on: December 19, 2008, 01:30:13 PM »
wiring diagram to Hood
Re: ports and pins
« Reply #5 on: December 19, 2008, 01:54:50 PM »
If the pdf is not the same as your BOB then is there any markings on yours?
Re: ports and pins
« Reply #6 on: December 19, 2008, 02:11:59 PM »
Hi Hood,
The markings are the same unless noted in the email I sent to Arturo. Did you get that?
Bob
Re: ports and pins
« Reply #7 on: December 19, 2008, 02:15:59 PM »
Ok just will read through and see what I make of it.
Re: ports and pins
« Reply #8 on: December 19, 2008, 02:24:56 PM »
OK I think you are needing 2 power supplies, one from the PC and the other should be seperate to preserve the opto isolation. The PC one goes to the 5V and 0V at the top of the pic and your other power supply goes to the 5V and 0V at the bottom of the pic. You need to keep the jumper wire in to enable the board.
Re: ports and pins
« Reply #9 on: December 19, 2008, 02:26:25 PM »
Oh just thought I better add, when I say 0V it is the connection that Arturo calles Ground (Gnd)
