Hello Guest it is October 30, 2026, 06:41:41 AM
Author Topic: John S Seig X3 conversion  (Read 52732 times)
Offline John S
  •  111 111
  • Nottingham England
« on: July 10, 2006, 01:56:41 PM »
Part way through a conversion of the Seig X3 mill.
Many have done this using the original brackets but I wanted to get it as compact as possible. I think they look horrible when they look like Prince Charles :D
Shows both axis with motors fitted, X still needs the rear shaft shortening.
Start of converting the Z mounting, drive will be by HTD belt at 5mm pitch.
Ballscrews are by NSK supported on matched pairs of angular contact bearings driving thru Oldham couplings.
Still a lot to do, some things are unfinished like no X screw fitted at present although all the parts have been made.
John S.
Re: John S Seig X3 conversion
« Reply #1 on: July 10, 2006, 03:39:47 PM »
Nice to see that you are using the cheap CRAP  ;D
www.newfangledsolutions.com
www.machsupport.com
Offline John S
  •  111 111
« Reply #2 on: July 10, 2006, 04:02:55 PM »
You have to when you are limited by the tools :D
John S.
BTW, did you see the error message I posted on Yahoo.
Bolt circle is still broken, post code comes up with a syntax error
« Reply #3 on: July 10, 2006, 05:34:11 PM »
I fixed it and there is a new 2.69 rev in the download of Mach3
www.machsupport.com
ynneb
« Reply #4 on: July 16, 2006, 05:40:50 PM »
Nice looking conversion John.
Keep up the good work.
« Last Edit: July 16, 2006, 06:19:00 PM by ynneb »
Offline John S
  •  111 111
« Reply #5 on: July 27, 2006, 06:54:40 AM »
Up to the test running stage now.
http://homepage.ntlworld.com/stevenson.engineers/lsteve/X3/DSCF0437.AVI
4.5 meg for those on dialup.
4th axis done just limit switches and a bit of tidying.
John S.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #6 on: July 27, 2006, 09:42:20 PM »
John:
 Very Sweet!!!!!
Art
(What software is running that puppy. :- )   )
« Reply #7 on: July 28, 2006, 07:30:51 AM »
AHHA!! I think I know what software it is ;)
www.machsupport.com
Offline John S
  •  111 111
« Reply #8 on: July 28, 2006, 07:50:00 AM »
Brian,
Crap answer :D
It's running Mach3 latest release.
Bit of extra tuning this morning and it's capable of 5 meters per min or nearly 200 in/min
Rather scary for a little machine. Just wanted to see how fast it would go to workout the safety factor on missed steps when it's set to a workable 1.5m/min or 60in/min
John S.
Offline John S
  •  111 111
« Reply #9 on: August 13, 2006, 06:15:43 AM »
OK the machine is now finished and is going to the Bristol show next weekend.
Many thanks to all who have helped in this with advise etc.
the finished mill. [ oops missed the Z handwheel blanking plate ]
The clean side :D   4th axis plug in the side of the electrical box.
The driver box. Claer panel fitted just for the show.
And the dirty side.
John S.
