Hello Guest it is November 11, 2026, 07:11:38 AM
Author Topic: Override Limits issue - does it relates to SS?  (Read 18170 times)
Offline Anton
  •  11 11
« on: November 20, 2008, 03:33:06 PM »
Just discovered that manual "Override limits" does not work. Red led flashes, I push a Reset button, but I can't jog out of the switch. The same time AutoOverride Limits works well, homing works well, limit switches themselves works well. Everything, concerning a limit switches, works well, except of a manual Override limits. Does it relates somewhere to SS?
Best regards,
Anton.
Re: Override Limits issue - does it relates to SS?
« Reply #1 on: November 20, 2008, 03:39:42 PM »
Not sure, I always have Auto enabled.  If no one else comes back with an answer I will try and remember to test tomorrow if I get back to the workshop in time, if not it will be Saturday.
« Reply #2 on: November 22, 2008, 03:02:08 PM »
It works but it's funky.  You have tho click the reset button 2 times.  Then it should allow you to move off your limit switch.
HTH,
Sid
Offline Anton
  •  11 11
« Reply #3 on: November 22, 2008, 03:02:43 PM »
Today I have tried this with PP version and manual limits override works well.
Best regards,
Anton.
Offline Anton
  •  11 11
« Reply #4 on: November 22, 2008, 03:05:07 PM »
Thanks, I'l bear it in mind.
Best regards,
Anton.
