Hello Guest it is November 13, 2026, 08:20:42 PM
Author Topic: using motoroutput as normal digital output  (Read 12978 times)
Offline tantan
  •  130 130
« on: November 19, 2008, 01:28:19 PM »
hi,
it is probably a silly question but I use mach with an I/O card with six motor outputs on it. for a my lathe i use only 2 of these motor outputs. what i need are a few more digital outputs to control things on my lathe. is it possible to use a normal motor output (step or direction) as a digital output.
thanks,
antoine
the netherlands
Re: using motoroutput as normal digital output
« Reply #1 on: November 19, 2008, 02:52:23 PM »
If you are meaning can you set up output pins for other than Step/Dir pins then the answer is YES :)
But if you have some weird kind of I/O card then maybe not :(
Is this I/O card you refer to just a normal breakout board?
Offline tantan
  •  130 130
« Reply #2 on: November 20, 2008, 11:25:42 AM »
hi,
thanks for your reply, i use the MACH 3 BREAKOUT BOARD from cncdirect. it is really an i/o board. but i will give it a try,
thanks.
antoine
