Mach Discussion => General Mach Discussion => Topic started by: tantan on November 19, 2008, 02:28:19 PM
hi,
it is probably a silly question but I use mach with an I/O card with six motor outputs on it. for a my lathe i use only 2 of these motor outputs. what i need are a few more digital outputs to control things on my lathe. is it possible to use a normal motor output (step or direction) as a digital output.
thanks,
antoine
the netherlands
If you are meaning can you set up output pins for other than Step/Dir pins then the answer is YES :)
But if you have some weird kind of I/O card then maybe not :(
Is this I/O card you refer to just a normal breakout board?
hi,
thanks for your reply, i use the MACH 3 BREAKOUT BOARD from cncdirect. it is really an i/o board. but i will give it a try,
thanks.
antoine
