Hello Guest it is October 23, 2026, 05:13:30 PM
Author Topic: Help using cutting fluid pump command (M7,8,9) to activate a switch  (Read 14268 times)
What is the procedure for activating the M7,8,9 commands to activate a switch?Thanks
Re: Help using cutting fluid pump command (M7,8,9) to activate a switch
« Reply #1 on: July 07, 2006, 07:52:15 AM »
M7 and M8 are going to be the flood and mist outputs. you have to set them up with an output pin and set that pin to the macro under the spindle settings in mach3 (under the ports and pins) and it is some place off the config menu in Mach2.
www.newfangledsolutions.com
www.machsupport.com
