Mach Discussion => General Mach Discussion => Topic started by: widpyro on July 07, 2006, 06:59:26 AM
What is the procedure for activating the M7,8,9 commands to activate a switch?Thanks
M7 and M8 are going to be the flood and mist outputs. you have to set them up with an output pin and set that pin to the macro under the spindle settings in mach3 (under the ports and pins) and it is some place off the config menu in Mach2.
