Hello
Guest
it is
October 23, 2026, 01:08:56 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Help using cutting fluid pump command (M7,8,9) to activate a switch
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Help using cutting fluid pump command (M7,8,9) to activate a switch (Read 14265 times)
widpyro
91
on:
July 07, 2006, 05:59:26 AM »
What is the procedure for activating the M7,8,9 commands to activate a switch?Thanks
Logged
Brian Barker
3,860
Re: Help using cutting fluid pump command (M7,8,9) to activate a switch
Reply #1 on:
July 07, 2006, 07:52:15 AM »
M7 and M8 are going to be the flood and mist outputs. you have to set them up with an output pin and set that pin to the macro under the spindle settings in mach3 (under the ports and pins) and it is some place off the config menu in Mach2.
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
