Hello Guest it is November 22, 2026, 09:17:36 PM
Author Topic: Is there a way to change m5 such that there is no "dwell" when spindle turned on  (Read 12578 times)
Say I put an edge finder in the machine and then set spindle to 2000 RPM and hit "spindle".  It takes about 5 seconds before I can jog to a new position.
I need that to be zero, cause when I try to tap at the bottom of the tap, the machine runs the spindle in reverse, bud does not feed back up till it runs the spindle for about 5 seconds destroying the threads I just put in.
Config menu then Ports and Pins then Spindle Setup, you can set the spin up/down  delays there, put it to 0 and it should be almost instantaneous.
Thank you, that worked perfect!
