Hello Guest it is October 30, 2026, 12:33:50 PM
Author Topic: External reset button  (Read 19446 times)
JAMMAN
« on: July 01, 2006, 11:21:07 AM »
I feel dumb, the drive works and the homing and limits work and everything seems smoothe till I tried to make an external reset. I was going to use an oem trigger but evidently I don't know the oem code.
I need an output also when in e-stop mode, haven't even tried it yet. Any suggestions? I did a search and didn't find anything.
Jim
Re: External reset button
« Reply #1 on: July 01, 2006, 08:25:15 PM »
I think the OEM code is 1021 :)
To get the Estop out you will need to make a Macropump ... I can help you if you need it
www.newfangledsolutions.com
www.machsupport.com
JAMMAN
« Reply #2 on: July 02, 2006, 07:14:27 AM »
Great thanks, I'm at home right now and will try the OEM code first thing Monday morning.
You wouldn't happen to know the one for cycle start too?  ;D
Anyway I'll read up on the macro pump thing this weekend so I won't seem like such an idiot then I'll catch on better.
Thanks for your help- I'll post a picture of my micro hole driller when I'm done with it.
I also found a place with really cheap IO cards that I made work with Mach3, I'm talking less than 20 bucks for 4 relays. If anyone is interested I'll post a link.
« Reply #3 on: July 02, 2006, 08:29:50 AM »
You will find a list of OEMS etc in the customisation Wiki, heres a link
http://www.machsupport.com/MachCustomizeWiki/index.php?title=Main_Page
« Reply #4 on: July 02, 2006, 08:49:48 AM »
Cycle start is 1000 :)
www.machsupport.com
JAMMAN
« Reply #5 on: July 03, 2006, 08:39:21 AM »
OEM codes worked perfectly (of course)  ;D
At least I can cycle the thing and get it set up mechanically now. After I get it going then it's Macro Pump time. Whatever that is..........
Thanks again!
Jim
