Hello
Guest
it is
October 30, 2026, 01:26:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Rapid positioning Rate for Dummies
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Rapid positioning Rate for Dummies (Read 15902 times)
creativeconversion
on:
June 30, 2006, 10:50:15 PM »
Sorry for what is probably a stupid question but how do I set a default rapid positioning rate
for plasma cutting
Barry
Brian Barker
3,860
Re: Rapid positioning Rate for Dummies
Reply #1 on:
July 01, 2006, 08:21:59 PM »
Go under motor tuning and test till you have a speed that you and your machine are happy with
Use the slider on the side to change the Velocity and test it by clicking on the graph with the mouse, them press the up and down arrows...
Good luck
Brian
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
creativeconversion
Reply #2 on:
July 02, 2006, 06:55:31 PM »
OK, I get it, the max speed set in motor tuning gives the rapid travell and the cut speed is set by the code
Thanks Brian
Barry
Print
Pages:
1
Go Up
« previous
next »
