Hello Guest it is September 25, 2026, 12:53:34 AM
Author Topic: Rapid positioning Rate for Dummies  (Read 15700 times)
creativeconversion
« on: June 30, 2006, 10:50:15 PM »
Sorry for what is probably a stupid question but how do I set a default rapid positioning rate ??? for plasma cutting
Barry ???
Re: Rapid positioning Rate for Dummies
« Reply #1 on: July 01, 2006, 08:21:59 PM »
Go under motor tuning and test till you have a speed that you and your machine are happy with :) Use the slider on the side to change the Velocity and test it by clicking on the graph with the mouse, them press the up and down arrows...
Good luck
Brian
www.newfangledsolutions.com
www.machsupport.com
creativeconversion
« Reply #2 on: July 02, 2006, 06:55:31 PM »
OK, I get it, the max speed set in motor tuning gives the rapid travell and the cut speed is set by the code
Thanks Brian
Barry
