Hello Guest it is November 22, 2026, 02:10:41 PM
Author Topic: problem limit switch motion  (Read 21399 times)
« on: October 22, 2008, 11:54:49 PM »
hi all
i am using the galil 2123 controller with mach3 software.
i have problem limit switch. when ever my limit switch interrupt my hole motion get stop even my reverse,forward motion.
example:  if my reverse limit interrupt my motion get stop then i am not able to move motor in forward/reverse direction.
again i have to manually reset my limit switch by moving motor manually.
please provide the solution.
Re: problem limit switch motion
« Reply #1 on: October 23, 2008, 01:58:36 AM »
Does AutoLimit Override not work for the Galil, you will find it on the setings page.
« Reply #2 on: October 23, 2008, 04:50:10 AM »
thanks hood
auto limit works for galil.
can you give the detail path where i can set auto limit override option.
« Reply #3 on: October 23, 2008, 04:59:55 AM »
If you look on the left hand side of the settings page you should see the option for turning them on.
« Reply #4 on: October 23, 2008, 05:41:53 AM »
i have set auto limit override button. then i try to move motor after limit interrupt using ( up/down button ) joging .
but didnot work.
« Reply #5 on: October 23, 2008, 05:54:07 AM »
Did you press the Reset button after you hit the limit? If you did then it looks like the Galil must do things differently.
