Hello
Guest
it is
October 17, 2026, 02:05:18 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
No Hotkey for estop in Turn
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: No Hotkey for estop in Turn (Read 15054 times)
derek
200
on:
September 13, 2008, 08:36:38 AM »
I can't seem to find the hot key for estop in turn. It's not the same as mill.
Derek
ftomazz
195
Re: No Hotkey for estop in Turn
Reply #1 on:
September 18, 2008, 01:57:27 AM »
ESC will do
derek
200
Reply #2 on:
September 18, 2008, 07:07:45 AM »
Quote from: ftomazz on September 18, 2008, 01:57:27 AM
ESC will do
Not on mine!
Derek
Overloaded
4,923
Reply #3 on:
September 18, 2008, 07:20:41 AM »
Hi Derek,
You can emulate it this way. Esc key is 27.
Pick any key you want. Just be sure that it is not used elsewhere by Mach.
RC
Overloaded
4,923
Reply #4 on:
September 18, 2008, 07:33:16 AM »
OR.....go into Screen 4, un-check the hotkey box then re-check it. Press the same button(`) as used for Mill.
Save the changes and the "`" will be the RESET button.
Not sure why the Esc doesnt work the same way..? ? ?
RC
Print
Pages:
1
Go Up
« previous
next »
