Mach Discussion => General Mach Discussion => Topic started by: derek on September 13, 2008, 09:36:38 AM
I can't seem to find the hot key for estop in turn. It's not the same as mill.
Derek
ESC will do
ESC will do
Not on mine!
Derek
Hi Derek,
You can emulate it this way. Esc key is 27.
Pick any key you want. Just be sure that it is not used elsewhere by Mach.
RC
OR.....go into Screen 4, un-check the hotkey box then re-check it. Press the same button(`) as used for Mill.
Save the changes and the "`" will be the RESET button.
Not sure why the Esc doesnt work the same way..? ? ?
RC
