Hello Guest it is October 17, 2026, 02:06:53 AM
Author Topic: No Hotkey for estop in Turn  (Read 15058 times)
Offline derek
  •  200 200
« on: September 13, 2008, 08:36:38 AM »
I can't seem to find the hot key for estop in turn. It's not the same as mill.
Derek
Re: No Hotkey for estop in Turn
« Reply #1 on: September 18, 2008, 01:57:27 AM »
ESC will do
Offline derek
  •  200 200
« Reply #2 on: September 18, 2008, 07:07:45 AM »
« Reply #3 on: September 18, 2008, 07:20:41 AM »
Hi Derek,
You can emulate it this way. Esc key is 27.
Pick any key you want. Just be sure that it is not used elsewhere by Mach.
RC
« Reply #4 on: September 18, 2008, 07:33:16 AM »
OR.....go into Screen 4, un-check the hotkey box then re-check it. Press the same button(`) as used for Mill.
Save the changes and the "`" will be the RESET button.
Not sure why the Esc doesnt work the same way..? ? ?
RC
